oddball101
- Jun 8, 2010
- 0
- Columbia SC
- Ranger
- Engine Size
- 5.0
Hey guys, I haven't ever posted in the urgent section before but now, well it is urgent.. I have been on barrowed time using someone else's car while I did my swap and now the time to give it back has come. Like most of us here, I bust my butt for a living and this truck is my livelihood. So here goes..
2000 5.0 Explorer swapped to 2001 Ranger 3.0 extended cab ranger
I have two sets of issues. One is the vacuum setup is leaking somewhere but that I can hopefully resolve on my own. The second and very real issues is the AODE/w transmission. I drove the donor a couple hours down from NC and had her purring and running even better before I began the swap a couple months after, giving her plenty of test drives in between.
My issue
Upon completion of the swap, she idles really only if the MAF is unplugged and that is for about 15 minutes before she dies. Again, I feel like I can hunt that down, but I am certainly not apposed to insight anyone may have to offer. I went to back out the truck to take her to the exhaust shop, and when I got out in the road, she wouldn't move forward in drive. I cycled through the gears and eventually caught 2nd and managed to coast most of the 1/4 mile to the shop (got lucky there) with someone following me. Same thing on the way back.
Since, I have been trying to figure out what to do about the transmission and I am at a true loss. She ran great the final drive before I shut her off and began the swap. Reverse kicks in like it's cool and I feel like I could back of a tree if I wanted but the forward gears are effectively none existent. I understand that the tranny limp mode allows for hydraulic gears only (reverse & 2nd). A friend of mine noted that in his experience, even when tranny's go bad, they still try to engage or do something, but not in my case. It just sat silent as if it weren't even there.
I have checked the fluids and the only thing I did during the swap was separate the bell housing from the motor (after pulling both out together) to install a new rear main seal. Then I just put her back together at spec torque and show-horned her into my ranger. The wiring (PATS, VSS, ABS) was relatively straight forward, believe it or not, I had more problems with the battery harness than anything but I got that figured out as well. I replaced two wires that connected to the OBDII port that were meant to be spliced (DLC - TN/OG & PK/LB), but have since resolved that as well.
Where I stand now is I am waiting for the intake gasket to come in the mail so I can get her fired up and re-store the codes so I can read them, but I have to wait until then Wednesday or Thursday hopefully).
-Park is normal
-Reverse kicks in as it should
-Neutral raises the revs a little
-Drive raises the revs a little but does nothing
-2nd barely engages but enough to move the vehicle
-1st does nothing
I want to think this is electrical because I do not even hear anything try to operate in the tranny when I am going into forward gears. It would be different if I was doing so and heard like a clunk or something and no movement, but in this case, it is like it is not even getting the signal. My wiring manual shows C180 (EPC Solenoid) connector a little further back and higher than the OSS sensor on the driver side, but I do not have one there. I found a sensor on the other side however, just behind a metal identification plate from which I read the "AODE/w". *This is not the other tag to the right as you are looking at the passenger side of the tranny.
By my description, is that the C180 connector for the EPC Solenoid and what does it mean if it is in a different location than what the book said (Older tranny instead?)?
Does the AODE/w wiring harness separate from the engine harness, and if so where is that connection? I'd be willing to pull and swap to check at this point.
I've never used a pressure tester but I have a friend that may be able to get one to me for a bit, any pointers there?
I cannot for the life of me understand why I am having this tranny issue when she ran perfectly fine before I did the swap.
I am pulling the codes again (didn't work the first time) as soon as I get the intake gasket in the mail and installed within a few days. I have listed everything surrounding my situation that I can think of.
I need help..
My issue
-Park is normal
-1st does nothing
I need help..
