Anyone put a carb'd 302 in a BII?
87dytnajeff
If you have i'd love to hear about your process and what you had to do the line things up and make them fit. I'm getting ready to put a 302 in my BII, and need a little help.
What transmission should i mate with it?
Can i keep my stock manual shift transfer case? Or do i need to upgrade to a more heavyduty one?
Do i need to change the rearend?
Can i keep the front twin beam 4x4 axle?
I can handle putting the engine in, it's the driveline i'm not sure about.
Any help is great help
Rock Auto 5% Discount Code: 70D65189E6D8FF: January 5th, 2022
dirtcowboy
NW Montana
FORD
2.9, 4.6, 4.0, 6.8, 5.0x4
v-8 BII
Carb'd 302
C-4 Auto trans
to keep the trans case, which is plenty strong for a 302, use the Advance Adapter.... adapter, bout $450 from them
Do yourself a favor and swap out the stock diffs and get the Dana 35/8.8 stuff from an explorer, pretty much a straight up swap
Make sure to check out the tech library here, lot's of good stuff.
kimcrwbr1
42
maplevalley WA
2.8l
Ranger - broncoII same thing except driveline length lots of information on rangers I have seen with 302 conversion
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Nope, never been done.
Eagle Point OR
FORD
2.9l FI, 2.9L FI, 2.8L
Even better then paying $450 for an adapter, find a C-5 Transmission from an 85-86 Auto ranger or BII from a junk yard,(About 200bucks.) Pull the tail shaft and bolt it up to your C-4....
Keep your crossmember/Transfercase and get the strength of a C-4. Also keeping your drivelines. Would trash the dana28/7.5 and grab a set of Explorer axles.(35/8.8 31spline.)
