Anti-slosh module
rlrnot
Dover, Ohio
3.0 liter
I have a 2004 Ranger with the 3 liter engine. I am having a gas gauge issue. Previously, I would fill the tank and then the gauge would go to empty. Sometimes it would start working after a period of driving. Other times I would reset the computer ( disconnect battery) and then it would work properly. Now it appears it just stays on empty. Does this Ranger have an anti-slosh module and could this be the problem? I appreciate your help. Thank you.
Randy
snoranger
Professional money waster
ASE Certified Tech
13,525
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
2004 should have the HEC instrument cluster. If it’s anything the F and E series there’s no separate anti slosh module. There’s a 30 second (or so) delay built into the logic in the cluster.
8,296
Welcome to TRS :)
Yes to above, you have an HEC(hybrid electronic cluster) in a 2004 Ranger
Google: Ford HEC Test mode
You can then test the cluster to see if its a cluster issue or a float/sender issue
rlrnot
Dover, Ohio
3.0 liter
Welcome to TRS :)
I did follow the instructions for the HEC Test but nothing happened. I held the odometer reset stalk in and turned the ignition to acc. ??? For your info the gauges do not sweep the dial face on startup. Does this mean that I do have an anti-slosh module and if so, could it be my problem? At this point I am confused. Thank you for your help.
Randy
Orca
37
USA
A month ago, I read up on this "HEC Test Mode" . I tried it on my 2004 4-liter 4WD Ranger. No go. I tried it every which way possible, read and re-read the instructions, watched 2 videos, but was never able to make it work.
A few days ago, I used FORScan's "On Demand Self-Test" on the IC (Instrument Cluster) node. That's an entirely different thing than the "HEC Test Mode", but it did do a gauge sweep, so you might want to look into that. Hope it helps. Good luck!
Kirby N.
March Truck of The Month
