Anti-Slosh Module Gone Bonkers
helpme
18
Hotlanta
Now, how to get to it. All the instrument cluster removal videos show screws that allow removal of the bezel surrounding the instrument cluster. But mine has NO screws. So, what is the secret here? Thanks.
rusty ol ranger
Im a Jeep guy now.
7,433
Michigan
177 CID
What year truck?
8,369
In a 1994 there are just the two screws at the ashtray
Then you can pull at the top of the cover where there are 2 clips that hold that part in
Google: 1994 ford ranger cluster led swap
Should be the first video
helpme
18
Hotlanta
Thanks. What goes bad on that module? I heard it was a capacitor. Went to Advance, OReilley's and they looked at me like I was crazy. Another chain called Genuine, who's been around a long time, knew what one was but did not have any in stock nor could he get one.
Surprised someone has reversed engineered it and posted a schematic on this here web. Thanks all.
helpme
18
Hotlanta
Pulled the module and the cap checked OK but I put a new one in anyway. Resoldered the circuit board. Now it doesn't pin FULL when I switch the key to run. But it still behaves strangely. I put $5 in and the gauge barely moved so now I'm thinking its the sender. Its 25 years old so I guess its time to be replaced. I've replaced just about everything on the truck. The only reason I keep it is that it doesn't require emissions anymore. I bought it new and have kept it going ever since.
8,369
You can by pass Slosh module, gauge just moves up and down a bit when cornering, i.e. when gas is sloshing in the gas tank
helpme
18
Hotlanta
I don't think its the slosh module now.
What's the best fuel pump assy to buy? I see some on Ebay for as low as $40. I'll be changing it by myself and don't want to pull the bed more times than I have to.
I saw a video on Youtube of how a guy "walked " his bed back by himself by going from side to side.
Thanks.
helpme
18
Hotlanta
Finally changed the fuel pump assy. Had to, as the fuel pump finally died.
That was a project for one guy pulling that bed back. But I didn't have to remove the bumper or tires. Used the 4x4 trick one guy used in a Youtube video.
BUT the fuel gauge is still a little wonky. I bought the Oreilly's one. I noticed the connections for the rheostat are totally exposed. Doesn't the presence of gas on those connections affect the reading?
Also I noticed some green something in the connector of the old one. The pins are gold and the only thing I can think that would be green would be corrosion of the copper wiring in the pigtail.
Has anybody had any experience with this? Thanks.
8,369
Gasoline doesn't conduct electricity very well so exposed wires/connections will not lead to short circuits
Corroded connections would effect fuel level sender as that's a resistance sender
16 ohms Empty tank
160 ohms Full tank
Corrosion causes higher ohms so gauge would show higher level than true level, or make gauge stay on full all the time
Gold plating on contacts does resist corrosion but its a very thin coating
If you have ever seen a picture of the Grand Canyon then you have seen what a fluid(water) can do to any "coating"(the earth) over time :)
Gasoline is a fluid and does slosh around in the tank, so..................coating can be worn off in places exposing the base metal which will corrode
And yes the copper wire as well
helpme
18
Hotlanta
Thanks Ron.
The green stuff is nearest to the black lead for the fuel pump motor. I put 12V on the old fuel pump motor and it did nothing. So it was definitely bad.
The gold on the pins looked good. Corrosion on the rheostat lead makes sense.
Here's what it does:
Jump in truck key on engine off. Gauge slowly pins out beyond F.
Then slowly drops down to E. Then after driving a while settles out 1/4 to mid gauge or so.
Did exactly this on the old one.
helpme
18
Hotlanta
Here's a thread on this:
Seems to be the Anti-Slosh module after all for Casperthealien (post #9).
Thats a hard part to find considering they only used them on OBD1.
8,369
helpme
18
Hotlanta
Thanks. I was told that OBD2 did it in software.I'm planning to bypass mine with the jumper. Its been a year since this started and fortunately I've never run out of gas, re-fueling by odometer.
8,369
Ford/OBD2 was first used in 1995 Rangers with the new EEC-V Computers that year, but 1996 Ranger was first using standard OBD2
OBD(on board diagnostics) is a communication protocol, like French or English is, OBD1 was fairly standardize but not universal
OBD2 was a "language" agreed to by Automakers worldwide so everyone was speaking the same language when it came to diagnostics
The engine computer itself runs its own software designed/written by that car makers engineers
OBD2 is just the translation software
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
How to do @RonD My gauge stays pegged at full. I’d like to try and bypass. Thanks.
