Another brake line replacement thread...
Rex2nr
Rochester, NY
Hey guys, Just got my 99 4.0 4x4 5spd with 4 wheel ABS running. I took it around the block for a first drive and limped back with a blown brake line- drivers front line rusted out. I've run new lines before but usually just get the preflared lenghts from the parts store. This will be my first time flaring and running all new lines.
I've read as many article and threads here and on other ranger/explorer forums as possible, but I still can't figure out ho many fittings I will need and what sizes and styles I'll need. Autozone's website doesn't even give great answers. I believe I'll need 3/16 line? What style fittings are on the ABS unit? To the rubber lines? The rear lines on the differential seem to have been replaced, so I will be stopping at the rubber lines.
Thanks!
cvar
19
Mazda
4.0L V6
Rex2nr
Rochester, NY
That's an excellent write-up! Thanks! My system isn't exact being 4 wheel abs, but seems similar enough. I really don't want to to make multiple trips to the parts stores...
Rex2nr
Rochester, NY
Done!
For a 4 wheel abs truck, 25 feet of 3/16" line and a 5 pack of 3/8-24 fittings are all that's needed to run lines from the abs controller to each rubber line. There is one Union around the torsion bar mount, but that can be bypassed if you wish.
Kroeter
Ohio
V6 4.0
Rex2nr,
Thanks for info. Just did half of the rear and replaced a rear cylinder. I'm sure I'll have to do other rear side and fronts soon.
How much of a PITA was it to run the front lines??
Rex2nr
Rochester, NY
The drivers side wasn't bad but the passenger... You need to get creative. I was work I with a 20' coil at that point though so it was fun to pass it through. Looking back, I probably should have started at the passenger wheel week and ran it back to the abs controller.
8,369
1994 Ranger 4.0l 4x4, extended cab
I just did the brake line running from RABS module(by front U-joint) to rear fitting(above rear axle).
The fitting in the rear was 10mm threads, front was larger 11mm maybe, but not the same as rear.
3/16 tubing though.
Got the new line in the frame without having to remove anything, but the odd ball fittings caused a few trips to parts store, so took a few hours.
