Another “What is this plug for?”
8,370
What are the wire colors?
Purple and green/yellow?
Could be for AC, do you have AC?
mtipton
10
Vancouver BC
2.9
3 wires. Purple, green and yellow. I don’t have a/c.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
The plug looks exactly like the a/c plug on my 89, in the same spot as well. My wires are black green and yellow. What year is your truck?
mtipton
10
Vancouver BC
2.9
Mine is a 92.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Yes it’s the ac plug. It’s the same as mine. my a/c has been removed so I use it to turn on my light bar. I hit the a/c button and light up the night.
Idea stolen! I will do this.
mtipton
10
Vancouver BC
2.9
Awesome, thanks for the help!
Nez'sRanger
68
Pennsylvania
2.9L V6
No way!!! That's an awesome idea! I deleted my ac years ago. Never thought of using the button to power something else!
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I figured why waste a perfectly good switch already wired into the fuse panel with a 30 amp fuse.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Alert alert!!!! Don’t use the a/c plug/switch for your light bar.
So it works kinda but I didn’t think it thru. As the weather has gotten cooler I I turned on the defrost and boom my light bar came on. Lol😂😆🤣. I didn’t think it thru. Defrost uses the a/c circuit to dry the air only on full defrost not when split with floor or panel. Crap! It was cool while it lasted. Sorry gang.
Edit. Read the whole thread. Issue has been overcome. 😎
fastpakr
2,832
Roanoke, VA
Couldn't you use a diode somehow to prevent that?
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
If so I haven’t figured that out. I just didn’t want someone to score a ticket for running their off road lights in the street.
8,370
If you want to pull out the Climate control panel you can cut one of the 2 Jumper wires that activate AC when in Defrost mode
Or un-pin it from connector, put tape on the pin
Below is a 1991 but was the same up thru 1994 with the Slider switch style Climate Control panels
