- Apr 15, 2012
- 26
- Brandon, Manitoba
- Ford
- Engine Size
- 2.9
Good evening everyone.
Most of you know that I'm in the middle of a resoration
http://www.therangerstation.com/forums/showthread.php?t=130031
I've used "Phosphoric Acid" on the underside of the cab (as rust prevention).
For those of you that have never heard of this, here is the information on doing it.
First off, I use this product:
WARNING !!!! Use rubber gloves, and do NOT get it in your EYES !!!!!!!!!!!!!!!!!!!!
use a small open container (sour cream container works nice),
DO NOT return unused acid to original container, once the brush has contacted rust, it will activate ALL the fluid in the container, (this is the reason for the seperate container).
use a 1-2" paint brush, and simply brush on (NO SPLASHING, you will get it in the eyes and it WILL FLIPPIN STING !!!!! and you will have to go to the hospital.....
a couple of small drops on your hands or skin will give you a metallic taste in your mouth about 30 minutes later
(TRUST ME< THIS IS NASTY STUFF).
Some photo's of the before and during (after will be added tomorrow afternoon)
Just lifted, still dirty
Just washed with pressure washer.
phosphoric acid treated (Just done).
Closeup of passengers side front mount
You MUST wait at least 24 hours before painting, (read and follow instructions on bottle).
That's it, the stuff is water soluable (when liquid) when dry, it's tough as nails, AND chemically converts rust into a black / grey primer, it KILLS RUST.
I have othe cars that where done 15-20 years ago and the rust has NOT come back in the area that was treated.
Greg
Greg
