amp gauge is a liar!
Craig, co.
ok so i got an 86 ranger a few days back and its not really road ready... when i came out yesterday (no battery in( in garage charging)) the gauge read dead center.... my question is can i replace only that gauge or is all as one?
and can slow gauges be solved with a can of 2 letters and a number?(wd-40)
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
an ammeter should be in the middle with no current flowing..... are you sure you have an ammeter?
wd-40 won't help slow gauges
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
then its fine. if it stays in the middle while the engine is running then yes there is a problem.
middle means no current is flowing. "D" means Discharging the battery and "C" means charging the battery
it should be in the middle with the key off
Craig, co.
no matter what i do it is stuck....
when it should have been pointing towards "D" it was right were it is in the picture
Craig, co.
is there a way to test if the gauge still works (i have the cluster out right now(speedo cable was a b****) and just wondering....)
Craig, co.
my solution to both problems was to tighten down all of the nuts on the one side of the cluster......
