Alternative for the trans dapt oil relocation kit 1113.
allnpt0
Bedford, IN
Here's another option I found. Looks nice. -10AN fittings.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
When I did our relocation, i went to a hydrolic supply place that makes custom hoses. took the fitting in and told them this is the threads i need 2 hoses made , they made the lines to spec. did the same for the power steering lines. post 107 has the pic.
hope it helps
Junk Collector
Truck of Month
4,792
Rapid City SD
I used generic hydraulic hoses from a farm supply place. They work great and were super cheap. Almost 10 years on my swap now and no leaks.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
I ordered my relocation from James Duff, and yes, it has the generic push on rubber hoses with hose clamps....I figure it’s only a matter of time before she leaks. I have also considered just buying more Russell braided hose and AN fittings and making it last a good long time, leak free.
svtcards
137
Lyman maine
302
3'' front 4''back
That's probably what I'm going to do.mind as well do it b4 motors in and u have no room to mess with it when it's in.
Daniel Black
44
Leicester, NC
302
205/60R15 & 225/60R15
I'm still dealing with oil leaks. I looked into the AN lines and fittings but there are so many options I don't understand. To clarify, is the issue with all push-lock fittings or is it just poor quality fittings provided with the Trans-Dapt kit. I can get different push-lock fittings if that's the issue.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Are you talking about the plastic hose (not rubber) that is incredibly hard to push onto the narbed fittings? I would just have hydraulic hoses made, or buy some Russel brand steel braided -6 AN hose and the fittings, google search how to attach the fittings to the hose, and be done with it
Daniel Black
44
Leicester, NC
302
It has the rubber hose with the push on fittings. I finally just got a pair of hydraulic hoses. Only $44, I should've went that route a year ago.
Ramcharger90
1,708
N/A na
306, Bcam,
Just buy the L&L products engine side oil filter adapter, Russell 10an fittings and 10an braided stainless line also Russell 10 an fittings. Also order 10an conical seals. Use plumbers dope on the NPT thread side. Im using the cheap Hayden oil filter peice also. No leaks no more problems for now.
insaneranger
42
Tennessee
302
225/40 R18
I have Trans Dapt kit #1613. It has a 90 degree filter bypass with two inlets & two outlets which eliminates any clocking issues. The kit includes 1/2" NPT plugs to block off the inlet/outlet you don't use. Instead of barbed fittings, use hoses with crimped on 1/2" NPT fittings. I've had it installed for over 15 years & have never had a leak.
svtcards
137
Lyman maine
302
3'' front 4''back
What kit do u have?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Never seen this thread.
Surprised people have issues. The manual gear trucks can use the 2.9 adapter with the stop nipped off.
But using tsc hoses or custom hoses with just the t/d bases, works well and generally sub 60 bux.
The derele and l&l stuff is worth every penny though. Nice stuff.
Ramcharger90
1,708
N/A na
306, Bcam,
Daniel Black
44
Leicester, NC
302
Neat. I have manual steering and I'd never heard that info. Would've been good to know last year.
