alignment cams:
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
several things regarding alignment cams... first, my truck doesn't have any, it's got the factory lock cams on it, so i need to replace them with the alignment cams before i can align it...
ok, for suspension components, i've always gone with MOOG brand stuff, with a few exceptions here and there, like wheel bearings... anyways, i was looking on rock auto, the full alignment cam kit from moog says it's good for -/+ 1-5/8" where as the moog cam only is -/+ 1-1/4, however, the raybestos version, which is a brand i trust for brakes... has a cam only kit that does -/+ 1-3/4 and a full kit that does -/+ 2-1/4
price isn't a huge difference, about $1 for comparable kits, and about $7 over the whole spread...
so is there a better kit? is raybestos a good brand for alignment stuff? obviously with raybestos having the larger range of alignment, it would be a more favorable part, but i figured i should see what you guys think...
also, it looks pretty straight forward to install and use, it is, right?
It's a stamped metal cam, like a washer with the hole off center, I would think that'd be awful hard to screw up. I'd get the Raybestos full set. If you ever need more than 2 1/4* you probably don't have any factory parts left up front.
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Cheaper ones can be softer metal and oval out on ya.... Just my experience. I've had jeep lca cams made with tool/die steel before to stop it from happening.
--weezl--
Law Enforcement
182
hell
Sounds good to me...
Neither raybestos, nor moog are cheap parts in your opinion though, are they?
Sent from somewhere naughty!
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Nope, used both along with ford parts and a set made by Specialty products. Never had an issue with any of em.
--weezl--
Law Enforcement
182
hell
sweet!
i am pretty sure i'm done with my order to rock auto, it has.....
2x lower moog problemsolver balljoints,
1x raybestos full caster/camber kit
1x stant lev-r vent rad cap
1x stant fuel cap
shipping
tax
rockauto discount
total, $85...
one "kit" does both sides for the alignment right?
what i'm getting is
RAYBESTOS Part # 6161011 Professional Grade
Contains Cams And Bolt; 0 Degree To Plus Or Minus 2-1/4 Degree; Front
kcm1582
39
Worcester, MA
I think that kit is for one side because both upper control arm bolts need to be replaced with the cams.
--weezl--
Law Enforcement
182
hell
yeah, the more i thought about it, the more i think you're right... which brings me to the next question... who aligns one side of a vehicle? so why would you not just sell a set of 4 bolts?
like who would get 2 brake pads?
