AJE Ranger K-Member Who's Done It!?
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
What's it geared at and what are you gonna re-gear to? Turbo stuff appreciates a little steeper gear than something n/a, the extra load helps build boost quicker.
clippii
41
New York
Hey you guys recommended fox body parts (rack/spindles correct?
I have a set of SN95 spindles (the 95-96 style) that I did not use as I decided to go with the racecraft drop spindles. DM me if you're interested in taking em. Love the progress so far!
Yotaismygame
196
Oregon
Splash 2wd
I did some measuring for what sway bars will fit the front. It appeared the stock one would work with different links. Talked with AJE and that is correct. They set it up to work with a ranger sway bar. Any mustang sway bar is too wide. Ill try running the stock one for now. It's only 23mm so pretty small.
clippii
41
New York
What kind of ends do you think it will be? I know for my 93' Beltech offers a 1 1/4" (31mm) front bar for only $260. Also love the interior!
Yotaismygame
196
Oregon
Splash 2wd
I bought some off Amazon I’ll post pics when i get them. But I’ve seen a beltech that comes with normal bolt and bushing style links. I’ll run the stock one for a bit before upgrading. I have more important parts to buy still.
Yotaismygame
196
Oregon
Splash 2wd
Even the stock sway bar makes for a flatter ride through the turns. Truck have never handled so well. I had to shorten the links I bought quit a bit. They actually fit better before I cut them but the sway bar was pointed up a lot. Shorter front mounts would have helped. Like I said though this will just be temporary. Pics really tell the story.
9335CB1A-F0A3-49DF-ACDD-9BA810111D1D.jpeg984B983F-9A14-44D4-BC15-09F3EB493AA5.jpegFD53E6A9-DF42-449B-BFFC-FC8258948B80.jpegFE253FF1-278E-4460-BC3E-FC1C36C364F9.jpeg
Eventually I’d like to get this or the 1.15 version
Yotaismygame
196
Oregon
Splash 2wd
The day has finally come! I was able to mock up the suspension. Really gave me a lot of motivation to keep going. Will continue to post more pics as I try and make this pig pretty for once in its life!
Everything line up okay?
27
Houston
So so, had an issue with my drivers side frame rail being slightly out of line. Ranger strapped around the frame to pull it together and the k member slid up nice and easy. Had to shave the edge of the pass side a arm ball joint because the metal ring stuck out of the bushing to far to slide inbetween the mounts. And one bolt hole had to be re drilled because it was slightly off but not bad at all tbh, I was really worried for a while with that frame being out of line but I think it’s just from taking the old suspension off and not having anything to hold it straight. Seems good now gonna bolt up my spindles and rack tomorrow or so. Maybe lower it on to the wheels and see what hits where. Thanks for all your guys help! Your pictures saved me hours of scratching my head haha
Yotaismygame
196
Oregon
Splash 2wd
Doesn’t sound too bad at all.
27
Houston
No not to bad honestly. Did you guys put locktite on your bolts when you did the final instal? Also was thinking about getting some more washers and running them on both sides of the frame instead of just the one like AJE provided
Yotaismygame
196
Oregon
Splash 2wd
No not to bad honestly. Did you guys put Loctite on your bolts when you did the final install.? Also was thinking about getting some more washers and running them on both sides of the frame instead of just the one like AJE provided
My kit came with nylon locking nuts. Did have to buy a crap ton of washers so I could run them both sides.
Yotaismygame
196
Oregon
Splash 2wd
I wonder if this link would have bolted right up
n2xlr8n
74
Bama
Ford Ranger XLT
LS
28x10.5
Great progress on you guys' rides since I last visited.
I've been slowly getting mine closer (waiting on the converter / driveshaft / shocks-struts made the project behind schedule).
Here's where I'm at currently:
I still have to remove the goofy Ford frame brace in front of the engine (replacing with 1-5/8" DOM tubing, as the AJE strut brace doesn't come close to fitting).
Final ride height set:
To dispel the myth that these trucks are out of balance and heavy (with me, 12 point cage and full 20 gal cell in it- I'm 196):
I'm probably going to be forced to play with the front struts a lot to prevent craziness- I've honestly never had a hotrod with 50/50 weight distribution. Good problem to have, I guess :)
