Aircraft vs Car
superj
2,571
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
that all i run in my titan here in town. when driving out of town i am pretty much stuck with what i can find. we have three places nearby that sell non ethanol gas so thats nice but it is a bit more expensive. but its only about 4 dollars more to fill up my half ton using that versus the corn gas so since i don't drink coffee, i figure that about a cup of coffee difference.
i like to put it in the ranger if i am going to town when the ranger needs gas. other wise the ol ranger runs on the corn hole gas
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
I make sure to run a couple tanks in the Ranger before it gets parked for the winter too.
That's a good idea, especially if the Ranger has a carburetor. I know it's more than half-way thru Winter but it should be stored with ethanol-free fuel in the tank. That'll ensure that when Spring arrives, the truck will be good to go.
85_Ranger4x4
17,767
SW Iowa
Mine has a carb.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Carbs aren't as bad as saturated fats.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
No, no, no... That's a fat trans...
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
don4331
1,342
Calgary, AB
5.3
Awhile back I bought a 3/4 full 45gal drum of toluene for $10.00. Now I know what I'm going to do with it....
If you're running toluene in a carb'd engine, you want to drop at least a jet size or the engine will be running rich* and you want a warm day - the fuel does not vaporize easily unless preheated to 70 °C.
*As opposed to Nitromethane which runs lean and you want to increase at least a couple jet sizes. At which point, I take the 5th.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for the info. Always wanting to learn...
Any other gotchas re toluene?
don4331
1,342
Calgary, AB
5.3
I played more with nitrogenated compounds: nitromethane and/or nitous oxide. If found it easier to disguise their presence (the nitric acid in nitromethane is very hard on exhaust pipes).
But if I remember correctly, being harder to ignite, we ran a bit more ignition lead. It didn't help the wife's '82 Mustang with 8.4:1 compression on her 5.0 as much as it helped the 410 in my F-100 which had 10.5:1 compression. It also ran a bit warmer on exhaust (the 410 has sodium filled exhaust valves).
The 410 liked a 50/50 mix of 100LL/mid grade unleaded best.
