Add circuit to Power Distribution Box
Caprock Rider
11
West Texas
2002 (3 trucks)
Ford Ranger XLT
All three 3.0's
all 15", from 225/70 to 31x10.50
To each their own ____. If it's no skin off my butt, then I couldn't care less.
Want to add a circuit to the Power Distribution Box (or if you prefer Battery Junction Box) for an electric cooling fan. Have been told that the PDB
comes apart (upper part lifting off), however, I don't see anywhere my PDB comes apart. My truck is a 2002 2wd Edge with 3.0/5 spd. Any suggestions?
This circuit would provide power to the fan via relay and be fused in the PDB.
Have already added a circuit with toggle switch to power the relay. That circuit starts at position 6 in the Central Junction Box, a hot with ignition on terminal.
A secondary problem is where to go thru the firewall with the control wire.
Caprock Rider
11
West Texas
2002 (3 trucks)
Ford Ranger XLT
All three 3.0's
Has anyone ever opened up a Power Distribution Box like the one found on a 2002 Ranger?
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
You can disassemble the box, it is possible, but all of the terminals are proprietary so you would either need to source those or a spare box to steal terminals from.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Your plan seems like an over-complication.
holyford86
610
Plattsburgh, NY
many
33x12.50R15
For the purposes of this, I agree, at least with the information provided. Personally I like using factory fuse boxes to power other things but I'm weird and have access to all of the spare parts I need to do these things, but it isn't always feasible or realistic.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
or 1 other option is to run the wire directly off the battery, can you lug ring a wire to the bolt for the terminal? as a fan could draw up to 30 amps.
Caprock Rider
11
West Texas
2002 (3 trucks)
Ford Ranger XLT
All three 3.0's
Thanks for your input guys. My plan was to add to the BJB whatever terminals needed to give me a 30 amp circuit to power the fan.
If I can also add a relay to the BJB that would be great, however, I do have a relay & saddle I could mount near the BJB.
This is not a show truck. It is my "work" truck but I still want things neat and tidy.
Agree that the easiest way would be to come off the battery with a wire. But, I'm not necessarily looking for the easiest way.
Want the end result to be well organized and uncluttered.
Intend to keep this Ranger and my other 2 Rangers forever. Thanks again fellows.
rubydist
857
Denver
Ford Ranger FX4
You can get a "add a circuit" from the parts store or online that will allow you to add up to a 30 amp circuit to the fusebox. That is how I have always wired up the fans on my vehicles.
Caprock Rider
11
West Texas
2002 (3 trucks)
Ford Ranger XLT
All three 3.0's
Thanks rubydist, I didn't know that.
