Acceleration/power issues. Timing? Misfire? Help..
Alaskaranger907
Recently bought a 94 ranger xl 4x4 v6 3.0 manual. When I accelerate it feels like it's just not getting all the power to the wheels..bogs going up hills, and acceleration isn't consistent. Rpms move smoothly, but acceleration slows and speeds up and so on, as if I was feathering the gas pedal...anyone have similar issue before or know what causes this?? Thanks.
bucko
A dirty MAF, a dirty/carboned throttle body, bad plugs or plug wires, dirty air filter, vacuumn leak(s).
Any CEL codes stored?
When was the last time the truck had a good "once over", meaning a tune-up/inspection?
Tractor Dan
Near Lima, Ohio
Idle air control valve is another thing to check and clean if it's all crudded up it won't work right.
Rearanger
23
Southeast USA
What's the idle like? What is it like when in neutral and you rev engine? Your symptoms can be blocked cat or other exhaust restriction. Vacuum test may show restricted exhaust when reving engine.
I doubt IAC.
Might also try fuel pressure test.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
Start by doing the throttle cable mod to eliminate any slack that may be present. It's super cheap and easy, and will ensure that your throttle is actually opening properly.
