Acceleration improvement ideas?
mud junky
22
NH
2.9L/4.0SOHC
I have recently gotten in to fast track mud drag racing with my 03 fx4 ranger. For an almost stock truck it does real well, but I am looking for ways to improve on my times. This is a 300ft drag, and I do it in 4low for max power and acceleration. I have yet to find the red line in 4th gear, so high end is not an issue. The way i look at it I have three basic options. Re gear the axles, find a way to get a lower range T case, or motor work.
If it can be done re-gearing the T case, or buying one with a lower gear ratio in 4 low seams like the best option. I looked in the tech section and did not see anything about being able to re-gear it, or any suggested T case replacements. But if I am missing something please clue me in because doing it this way would help my racing a ton without any negative effects on street driving or gas mileage.
Then there is re-gearing my axles. I could be wrong, but it just does not seem to make sense to do this. I currently have 4.10s and 33" tires. To me it does not seem cost effective to go from 4.10 to 4.56, and 4.88s worry me for several reasons. I could be wrong, but i think that this is too deep of a gear for the front end. When I re-geared my B2 to 4.56 the pinion gear in the front was tiny, plus with the ring rear so thick we has to shave down one of the pins in my carrier to be able to put it back together. Also 4.88 and 33's seems steep as hell for street driving, and would likely do a number on my MPG's. Am I wrong about the 4.56 not being worth it, or the 4.88's opening me up for issues?
Lastly the motor stuff. I am not a mechanic and i don't play one on TV, so ripping my motor apart really is not an option, leaving me with "bolt on" options. Intakes, exhaust, and computer chips just seem like gimmicks to me.
They all claim to give big hp gains, but most guys who have them seem to say they ether got little or nothing out of them. The two things I have looked at that seem promising are an electric "super charger" that I saw advertised on hear. http://www.superchargertuning.com/Ford/Ranger/ . And or Nitrous. I know nitrous is the best bang for my buck, and at some point I do plan on adding it to my ranger, but I can only use it in one of the two classes I race in, so it can not be the only thing i do.
Last thing I have thought of doing is dropping my race tires from 33" to 31" but this could be a catch 22. some times the drag lanes can get rutted up, and if I am dragging frame I am screwed.
Sorry for the long read. I just wanted to give you all the info I could to make it so you can give me the best possible advice. Also so none of you would think that I expect you to do my research for me. Thanks for taking the time to read.
PanamaExpat
13
Panama City, Rep. of Panama
Mazda
4 liter
Put on a doubler. Since yer going in a straight line if its not yer daily driver Lincoln lock your diffs. If it is used for other things get a set of lockers.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
panama since he said he is worried about mpg i would think its his dd to so lincoln lockin isnt an option. but i gotta ask wouldnt a doubler make it crawl better not have better acceleration?
mud junky
22
NH
2.9L/4.0SOHC
yes and yes. it is a DD. i don't need a locker. traction was not an issue. i am just looking for more acceleration. And a doubler would make my ratio to slow. my T case is something like 2.47:1. double that and you are looking at 4.94:1. that's way to low. Im thinking something like 3.5:1 would be good.
straycat
77
02 06 and 2012
Jeeps
Wow!! Didn't we have this post about a year ago? It sounds just like one we had on here I remember reading about the same thing. Really weird. I thought it was deja vu, Eh?? lol
mud junky
22
NH
2.9L/4.0SOHC
yes and no. I did post about looking to improve on my 2.9l B2. this is for my 4.0l ranger. plus i have different goals this time. and different tires, and different gear ratios, and different just about everything. And I never even brought up T cases last time. so ya not a double post. :thefinger:
this is the tread i started, that I think you are referring to. Read it. totally Fing different.
http://www.therangerstation.com/forums/showthread.php?t=125461&highlight=drag+racing
Frank The Tank
43
South
You should gear the heck Out of it and run in 4 high.
mud junky
22
NH
2.9L/4.0SOHC
do you know how low I would have to gear it to make up for running in 4 high? I even posted in the OP that i was worried about dropping in 4.88's.
87anger
Nevada
177 c.i. 2.9L
Do NOT get that electric supercharger. They are all scams and do not work. They only push air, not compress it like a real supercharger. please do not buy it. save your money.
Tarryn
Utah
You're not going to get 100+ hp from exhaust and intake, but there is definitely a noticeable difference in acceleration.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Lose weight. That's free.
Richard
Jonny Boy
Columbus, Nebraska
Mazda
4.0L V6
87 is right, those electric fans are absolute crap. Most likely you'll just end up sucking chunks of them into your engine..
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
Lose weight.
Regear axles.
Real engine modifications - headers, exhaust, intake, port/polish, chip when you're done.
You're not going to be able to run a big shot of nitrous nor pour it in for the whole length of the track. Your motor just isn't built for it.
OOOOORRRRR.....
Go 5.0L. That'll get moving in a hurry. Done right, it'll even look stock. I'm not sure how bolt-in it is for an 04, but I know that a swapping one out of a 99 Explorer into a 2000 Ranger was nearly bolt in. Had to splice something like 5 wires and drill one hole (drivers side motor mount). Of course, then it's on to working out all the gremlins that come with such a swap, but.... stomping on the go pedal is SOOOO much fun, lol.
naford
12
You have to put a dollar amount on this project. What I would suggest is to look into either a supercharger or turbo. Just don't go above 8 lbs. and you shouldn't have a problem with the lower end of the motor.
mud junky
22
NH
2.9L/4.0SOHC
don't really have a set budget. I do have rules i have to work within. No V8 swap. I can't do a "real" supercharger. If it did get good reviews I could have gotten away with calling that electric one a turbo. I can do turbo though. I asked several questions that did not get answered in the OP though. Is it cost effective/ worth it to go from 4.10 to 4.56? Is 4.88 to deep for running 33's on the road? would 4.88's be to much for the front end and cause issues? I am also digging deeper into the lower range T case. Looks like I could get an Atlas 3.8:1, but from what i have read it has only been done twice in RBV's and both times it was done in explorers.
