AC Works but Compressor Short Cycles
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I recently bought my Ranger last year. The AC worked decently cold, but the AC pump comes on and shuts off every 10 seconds or so. Is this normal. 93 Ranger 4.0 XLT. When I bought the Ranger used last year, I'm not sure if the old owner went to the new freon or not. If it's not broke dont fix it I suppose.
Uncle Gump
Token Old Guy
13,455
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Typically that means the system is low on charge.
See how it cools one it gets warmer... if it doesn't properly cool it's most likely low.
If it's been converted... the service ports will have 134a adaptors.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Yes it has the 134a service ports. And its been cool here in NY, so I'll take your advice when the weather starts to get warmer. Thanks
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
I put in about 1/2 a can yesterday and it's not short cycling as bad now. So yeah it was definitely low in freon. I don't want to overcharge it, because it's cooling really good now.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
Get yourself a set of gauges from Harbor Freight, they usually go for about $50. Then you will be able to get a more accurate reading on how the system is behaving. It may sound like a lot of money compared to those cans that come with the little gauge with the trigger. However, not knowing the high side, you may end up over pressure on the high side.
It is possible you may have a very small leak as well. You will just have to keep an eye on it.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
No leak. And the gauge on my AC refill kit works pretty good. I just got the Ranger last year. And it cooled decently. This year I want to give it a little charge.
Uncle Gump
Token Old Guy
13,455
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well... if the system was low... it has a leak. They can be tough to find.
As for a set of gauges... they are a really good investment if you maintain your vehicles yourself. It's nearly impossible to perform any real diagnosis of an A/C system performance using only a low side gauge.
