- Jun 2, 2012
- Reaction score
- 8,298
- Location
- canada
- Make / Model
- Ford
- Manual
Look in the engine bay where the black vacuum line goes into the cab, there will be a second vacuum line with it, usually Grey color, follow it
If its not plugged in then plug it, that vacuum line is only used with MAX AC, so if its open you would lose what little vacuum you have in the cab
It was used to cut off coolant flow into the cab, operated a by-pass valve on the heater hoses
