- Oct 22, 2007
- 1
- Muscatine, Iowa
- Ford
- Engine Size
- 4.0, 2.3 Duratec
So.. I have a '94 Exp Sport and a '96 Ranger Splash. Both have the same gearing, mostly the same parts and are both 4x4 / 4.0 / 5 speeds. I bought the Ranger last spring for my winter truck and knew when I bought it that the front axle wasn't working; thought it was the hubs.. Anyway, no biggie because I have the Exp to pull from. I got to looking further and found that the pinion gear had been blown off the shaft and it took flight through the differential housing. Still not a big deal because I have the exact replacement for the diff in the Exp right? Right....
I pull the hubs and find that because the Exp has front ABS that the Speed Sensor has to be pulled. Well there's 2 bolts that hold the cast "shield" into place to protect the sensor. One is a 6 point 8mm, the other is a 12 point 6mm. You cannot pull the axle withouth removing this and this is where the journey starts..
I called around all over 6 cities here in Iowa and NO ONE has one. My buddy got one of the bolts out with a 1/4" 12 point socket, but the second is too tight so after 2 full days, I took a coal chisel to the second one. I call the Ford dealer and he supports what I'd already figured; it's just a 12 point 6 mm socket. So he gives me the Snap-On guys number. Well, he doesn't have one and has to order it up.. (two blown weekends) after he dangles me another week, I order one from Sears in a 3/8" drive. Third weekend blown because the diameter of the socket is too big to fit, and I need the sensors in tact on the Ranger, so I can't just bust them out at $60 each. So I had to order an Allen brand 1/4" drive through Sears which is due in this week... Allen, because Sears doesn't market a 1/4" drive 6mm 12pt..
Now SURELY I'm not the only one who's run into this little issue?
