Camo Ranger
- Nov 24, 2009
- 0
- Eastern MA
- Ford
- Engine Size
- 3.0L V6
Hey everyone,
99, 3.0 L, 4X4
I've been searching through past threads about this issue and it seems that many have experienced the same problem but no one has posted a definite fix.
My problem is this that when I go to stop (<5mph), my ABS kicks on right before you would expect the truck to stop, causing the truck to go a few feet further than it would normally. Definitely not warped rotors, as this issue has persisted even with the new pads and rotors that I put on less than 1,000 miles ago. Also, usually the ABS light will turn on when this happens and the truck pulls to the left slightly.
To make matters more interesting, randomly my speedometer will start jumping from 0-80mph, the abs light will kick on, and the truck will "buck" almost like the brakes are engaged when the speedo hits 0mph. I tried replacing the sensor in the rear differential and cleaned the connection there, but it didn't help.
I tried scanning for codes and came up with P0503 "Vehicle Speed Sensor (VSS) Circuit Intermittent".
I'm not really sure where to go from here. I would appreciate and suggestions on what to check/replace next. Oh, and the truck does have 4WABS.
Thanks,
Dan
99, 3.0 L, 4X4
Thanks,
Dan
