nsmar4211
- Apr 9, 2018
- 2
- Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
Realized yesterday when hunting down my wipe motor fuses/relays that both fuses in the engine fuse box labeled for the ABS brake system are....just not there. Only a couple people have worked on it since I've had it (since 2005) and none of them removed them which means, they've not been there in a very long time. My ABS/Brake warning lights have been coming off and on since I've had it, most of the brake system has been changed with the exception of a proportioning valve. I've never noticed an issue using the brakes once the new cylinders/pads were done other than if you have to slam on them it triggers the ABS/Brake warning lights and they won't go back off for months. Should I put fuses into those slots and see what happens if I"m not actually having brake function issues? I don't live in an area that gets snow or ice. 1999 V6 Ranger. Thank you!
