A4ld sticking overdrive servo, and no governor valve?
Chuckc
Florida
Bronco ii
Hi guys,
So I’m in the process of overhauling 1988 A4ldld 4x4. I’m replacing servos in overdrive, reverse and 2nd. I ordered the servos based off letters in caps and put them in. Here’s my problem 2nd with the bigger spring springs back to position when you push in. When I push in overdrive it gets stuck and Does not return to original position-on it’s own. I polished bore with scotch brite and a bit of fine sandpaper. Is this normal? Do I need a new spring or heavier spring? The spring that is in their is .079 thick I attached picture of spring chart could I go up to the next size? I don’t have experience with this. Also has anyone tried the sonnex reverse sleeve kit? I’m in process of installing that to! Picture is showing servo not returning back against c clip. Lastly their was no governor valve in governor just the spring and having trouble locating one. Is this needed?
