wildbill23c
- Aug 22, 2012
- 577
- Southwestern Idaho
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 2WD
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70-R14
- My credo
- 19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Is there a better alternative to the A4LD that'll swap into an 80's Ranger or Bronco 2? Keeping with an automatic for this possible, upcoming work. I thought a C3 or C5 would work, but if I recall in a previous mention that some modifications would have to be done to the shifter assembly as the A4LD has a 4 speed shifter and C3 and C5 only had 3 speeds...I'd assume one could swap the C5 in along with its shifter assembly and be ok...but doesn't the A4LD rely on the ECM for torque converter lockup?
I won't mind losing overdrive, it won't be a highway commuter, just short distance highway up to the hills. Would be going into an 89 Bronco 2, or an 88 Ranger depending on which deal works out. Both need transmissions, but run great otherwise...The Bronco 2 will move on its own but doesn't have overdrive, acts like its in neutral when it goes to shift into overdrive...the Ranger only moves barely forward or reverse.
