- Sep 13, 2020
- 273
- Texas
- Ranger FX4 LVL2
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2 inches in the back, not enough in the front
- Tire Size
- 32x11.5x15
Glad to assist.
My front height BTW is: 35" from the lower inside fender lip (just above the 31.6" tire) to the ground. The other side is 35-1/4" on uneven ground. This is with the plastic fender lips that come stock. So I'd add a quarter inch to my numbers if you don't have those. Again my front lift is about 1.5" higher than stock.
You've got some really dynamite responses, congrats on that man! Thought aside, if you're going into that front end, it's really not that hard to remove & replace (R&R) those upper & lower ball joints, lower A arm (new ball joint already installed) CV axle, steering arm, sway bar bushings, shocks. Something that can be done in a day. At least inspection time has already arrived, and should be considered.
I'll admit, when I removed my T bars, my 3 pound shorty hand sledge and a chunk of steel, think it was a 6" long half inch socket extension, only hit it 3-4 times and it came right out with the rear T bar mount assy loosened up only a few turns of the bolts with the front frame resting on some jack stands. The 1/2" extension did not suffer any damage at all, I believe I released all the tension before it slid out rearward. It was stuck at the back if I remember requiring some lube the night before & heat the next morning. Doing the wrong thing the right way??
