Eddo Rogue
- May 18, 2020
- 2,502
- Burbank,CA
- Ranger 4x4
- Engine Type
- 4.0 V6
- Engine Size
- OHV
- 2WD / 4WD
- 4WD
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Gonna try again to swap in this efan...this time using a non adjustable switch.
I would like advice on what temp range to use, and where to install my thermo switch.
If temp range depends on thermostat, I'd like the ranges for both a 180 and 195 thermostat.
I have hose adapters to run the fitting in the upper or lower radiator hose, or heater hose, would like ideas on where to start first, and hopefully last.
BTW Its a '93 4.0 OHV 5 spd manual w/ the thin core radiator if that matters. Also I have no cooling issues at the moment (just about everything's been replaced)
The temp ranges confuse me a bit. for example if the temp range is 200 on and 185 off, and I have a 195 thermostat, wouldn't the fan always be on? Or does the location difference affect the temps enough to where the range needs to overlap in order not to? Or do I need a higher temp range w/ the hotter thermstat?
