A different kinda diesel...
Crazy Dan
New member
Cassville, Missouri
Last Christmas, I bought 2006 Mazda 2.0L turbo diesel complete power-train from a JDM importer with the intent to put it in my 32' pickup build. By the time it arrived, I discovered it was not going to fit. The tranny is manual, and as far as I can see, I am not going to fine any other tranny to fit very easy. Add to that, the included computer is all in Japanese and I can't seem to find any conversion info on the engine.
Enter the Ranger...
I have tentatively decided to put it into a later model Ranger. But one that I am looking at is an auto and my engine/tranny package is 5-spd manual, AWD/4WD. I tried to sell the package, but it loooks like I am stuck making an all-terrain, daily-driver to go to town and get the mail in...
My questions start with, ... What is involved with a 99' supercab w/ auto trans, converting the peddles to a manual? Is the floor shift as straight forward in the newer models as it was in the mid to late 80s? (that is where my Ranger expertise is now.)
Is the instrument cluster as screwed up in the Ranger as in the Jeep TJ series? (I put a Cummins 4bt in one - what weeny dash set up for factory...)
Is there any place that can help me with the remapping of a Japanese diesel RF engine computer? (Enquiring minds want to know)
I am open to all suggestions at this point. Even passing on the this particular Ranger for a better match.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Well-known member
1,808
You can swap out the pedal assembly pretty easy, and swap to manual steering column as well if you want
The floor shift cut out will be there under the carpet in an automatic
1999 Ranger dash/cluster is still analog for the gauges if that's what you mean, although Tach connects to computer for it signal, not sure what the diesel used for tach signal, but there are a few interfaces that can be used for that
1998 to 2000 Ranger used rear axle ABS sensor for speedo and cruise so easy to keep them working in a engine swap
The GEM module, is the Body computer, in 1995 thru 2003 Rangers, and has no needed connection to engine computer
GEM did run 4x4 system in 1995-2000 Rangers
Not familiar with your diesel setup so can't say what it would need from the Vehicles system to work, I wouldn't think much, just 12v and grounds, and, of course, new fuel system
Crazy Dan
New member
Cassville, Missouri
1999 Ranger dash/cluster is still analog for the gauges if that's what you mean, although Tach connects to computer for it signal, not sure want the diesel used for tach signal, but there are a few interfaces that can be used for that
Thanks, Ron. Will look into all this.
