99 ranger transmission issue
koths211
ranger x3
2.9l,4.0,2.3,3.0
so I have a 99 ranger xlt 2wd ext cab auto trans 3.0 engine
putting a different trans in the truck.
TC went in transmission first and clicked in 2 times.
put trans up to engine...everything lined up...
put 1 bolt on either side of trans. ( where the alignment pins are on the block)
i turn the flexplate with a screwdriver to make sure everything still spins freely.
as i tighten these 2 bolts down it gets harder and harder to turn by hand.
i stopped and backed them off so i didn't ruin the pump...any ideas on what it could be or what i should try?
thanks. Ryan.:icon_confused:
You should try putting the converter in the rest of the way. It's 3 clicks.
koths211
ranger x3
2.9l,4.0,2.3,3.0
i was told it is only 2... i had it in there 3 clicks earlier i think but when i turned the converter it sounded like it was hitting the bell housing. idk...ill try three clicks...
should the 3rd click go in like the 1st 2....
spin & push....1st click....spin & push a little more...2nd click...
should the 3rd be the same way???:icon_confused:
