kburley
- May 10, 2013
- Reaction score
- 0
- Location
- southern ontario
- Make / Model
- Ranger
- Engine Size
- 4.0 sohc
- Automatic
Hello everone, I have two irritating noises in my clutch system and need help figuring out what is is so I can fix it. I am new to forums, and any bit of help is greatly appreciated
1-when starting from first and sometimes second gear (especially when cold) and riding the clutch just a little too much, a loud squeal is heard, only for a split second. As long as i launch slow and keep the rpms down it does not happen. The sound is coming from what seems to be the bell housing. I cant figure out what it is despite hours of research and consulting with local shops.
2-wether the truck is running or not, when the clutch pedal is pressed or released, there is a low pitched squeak somewhere in the system. I do not think it is linkage and the noise is loud enough to be heard from quite a distance. I am far more concerned about the first problem, but like I said, any help or knowledge is greatly appreciated.
The truck has fairly low kms (100,000) and the clutch itself is still good (or is it?)
Please ask questions if need be, I will supply as much info as possible. Thanks!
