Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Does anyone have the fuel pressure specs / procedure for a 1999 Ranger 2.5??
Just had to replace my MAF, exact same symptoms.Actually I figured out how to do this. The pressure was 66 PSI with the car running. I turned the car off and let it sit for 1 hour; the pressure dropped to 30 PSI. After 2 hours the pressure was 0 PSI. Under partial throttle; the truck will hesitate at times (full throttle is ok). I was able to make the truck hesitate under light throttle when the fuel pump tester was on the car and the fuel pressure only dropped to 64 PSI. So I guess I have a leaking injector or a bad check valve in the gas tank. FYI, the truck is throwing no trouble codes. Also I just COMPLETELY tuned it up with Motorcraft parts (plugs, wires, pcv, fuel filter, air filter). Any thoughts? Thank you !!
