'99 Door latch frozen, have to cut. Best way?
Blue99
New member
Chicago
My son's 1999 Supercab has the infamous stuck rear passenger door. The cable/handle/release works just fine,
it's the guts of the latch that are rusted and won't release. It's frozen. PB Blaster, etc., no-go.
We have a door from the boneyard in the right year and color, so we just want to remove this door.
I believe I need to cut the part the latch grabs, the "catch bar" that attaches to the body. Due to a rust hole that
my son is willing to expand a bit, we can get a hacksaw blade on it. I -think- that's the way to go, but slow.
For those of you that have cut your way out of this problem, how did you go about it? Is poking a hacksaw blade
in there a slow but workable idea?
I'm about ready to take a cutoff wheel and the remove the whole lower corner of the door!
Thank you for your time.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
sheep herder
Well-known member
556
sheep pen
If it ain't broke, break it.
I'd cut the door apart. The part attached to the body is probably gonna be hard to cut. That said, I've never actually seen a supercab with rear doors so I might not know what I'm talking about. :LOL:
19Walt93
Well-known member
786
Canaan,NH
351
I'd cut the door,too. Stuck rear doors are only "infamous" on poorly maintained trucks, usually serviced by Jiffy Lube or another place that doesn't lube hinges and latches. I worked at a dealer from 1975 until 2017, we never had to replace a latch on a truck we serviced. We used to see a lot of door ajar lights on that we'd cure by lubing door latches,too.
Blue99
New member
Chicago
Thanks for your thoughts guys.
pjtoledo
Well-known member
434
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
I have the same problem, drivers rear door won't open. the pass side catch bar is severely rusted, I'm sure the pass side is too.
that catch bar lists at about $120 last time I checked. (I passed on that one)
there is an inspection hole where you can see, with great difficulty, the latching mechanism.
I did manage to get a thin tool in there but it did no good, the rust had jammed the mechanism.
my plan is to get under the truck and drill up thru the 2 screws to release the catch bar.
that won't be easy either, need holes in the rocker for access, probably a good carbide bit and a tube secured to the screw to guide the bit.
my door is in good shape, cutting it is the last option.
