The pump did run with pins jumped out using the previous’96 PCM. I had the Autoparts swap out another one with me. I have not tried to cycle the pump by jumping the relay pins with this "new" '96 PCM but did try starting with cam sensor unplugged.
When I put the first ‘96 PCM in, it started so suddenly it really caught me by surprise. It would run until it ran out of fuel, jump feed the fuel pump, fill the lines, it would start and run until it cleared the fuel lines. Maybe ten times total, showing a friend or two that stopped by to pick up something, etc., Then, for no reason I can determine, it quit starting up. I let it run out of fuel the several times I started because she has no coolant. I had the system open, putting in the additional temperature sending units for the electric fans. System is closed today, ready for water.
But I guess the questions are; "Why does it no longer start?" And, "Why does the fuel pump cycle during the KOEO test but not to start it using the '96 PCM?"
