98 steering pump with 90 steering box.
Ramcharger90
1,708
N/A na
306, Bcam,
Does anyone know if the power steering pump lines from a 98 exploder will work with the 90 ranger steering box? ( The fittings that go into the steering box) I want to get the lines from the exploder since they dont have all those stupid bends in them. I think I threw out the ones from my 98 mountaineer I got the engine from and Im sure that got crushed already the scrap yard just wanted the fuel tank before it was smushed.
Ramcharger90
1,708
N/A na
306, Bcam,
No on both
Bird76Mojo
1,265
IL
My local Napa took a new line that fit my Thunderbird pump, cut the other end of the hose and crimped on a new hose end that had the fitting for my steering box. Fairly expensive for what it was, but worth it in the end.
Ramcharger90
1,708
N/A na
306, Bcam,
My napa store is a joke they never have anything in stock I need or fancy equipment. I went to a one of the places that makes hoses and for liability reasons they wont cut and put a new end on I got a few places to try still. I did try to drill out the old fitting from the ranger line and flare that end but I didnt have time to mess with it too much
Bird76Mojo
1,265
IL
Napa had me cut the hose to the length I needed. The hose end they crimped on was just a normal hydraulic hose end that all Napa's carry.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
If a 98 Explorer is rack and pinion steering the pump flow and pressure may not work right on your recirculating ball box.
Ramcharger90
1,708
N/A na
306, Bcam,
Can the power steering pump from the 90 2.3 ranger be mounted to the exploder accessory brackets? I just haven't spent any time looking into that.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I'm not sure if the pump will fit the newer bracket but I suspect it will. There's apt to be someone here who's used the later pump and could tell you for sure if it would work. The original pump would have been a C2 pump which Ford released in 78, they were rebuildable by mechanics and easy to work on but unfortunately they were/are usually noisy. I like Mercon III spec transmission fluid best for p/s fluid, Mercon V isn't as slippery
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Never
Any
Parts
Available
Ramcharger90
1,708
N/A na
306, Bcam,
You would think that would be common knowledge on here a 98 pump wouldn't work with a 90 box considering the amount of guys that use the exploder accessory brackets. But I could be wrong
Ramcharger90
1,708
N/A na
306, Bcam,
Im gonna try it and then we can post it for all to see.
The PS pump from a 98 Explorer 5.0 is different. Looks more like the one from a SOHC 4.0.
The 5.0 pump is a Cardone 20277, the 4.0 pump is a 20279. I have used a 20279 with a recirculating gear box and had it work. If you can get lines made it should work.
Ramcharger90
1,708
N/A na
306, Bcam,
I got an exploder line cut off the box end and then drilled out the old fitting from my old rusted out ranger pressure line so the 3/8 line will fit in and flared it. Withe the same kind of flare as the old line if it leaks im out 6 bucks ill mess with it tomorrow some more
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Video I used to convert mine to Volvo and ditch the belt driven squealing pig:
If you do decide to go with one, the pump side fitting thread size is metric 16x1.5 with a flare. I wound up using 16x1.5 o ring with 6 wraps of blue monster thread tape. I should have preserved the hard line from the donor, but I messed it up when I pulled the pump.
Oh, and he talks about rhe Mazda 3 pump as well. It's slightly different than the Volvo - instead of a 12v sense wire for activation, it uses a alternator sense wire that rubs directly back to your alternator. Super simple.
Ramcharger90
1,708
N/A na
306, Bcam,
Im interested in doing this but what year and model Volvos?
