Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
im not going to run coil springs im just asking if you just run the leafs on the axle coil padsWhy would you have coil pads if you're going with leaf springs?
What axle?im not going to run coil springs im just asking if you just run the leafs on the axle coil pads
can i keep my 5spd manual transmission or does it have to be one from a 4x4 rangerIf you swap in a solid axle then a 4x4 transmission (or convert yours) then add a transfer case and a front driveshaft then yes...
you dont have to SAS it to be 4x4 you can just buy trans,t case, frontend and drive shaft from a stock 4x4 ranger and not mess with all the mods needed for a SASis it true that if i SAS a 2wd it will be 4wd?
oh i thought they used the same frames but just had an axle in the front and a tcaseNo, you can't really do that on any Rangers shy of the Edge models that were just missing some parts, the rest of the Rangers have different engine crossmembers and other bits that are hard to swap over... it's honestly easier to find a donor frame and swap bodies, that's what I did...
