97 Ranger XLT rwd wheel + tire sizes.
stephen1231
Hey all, I have a 1997 ford ranger XLT RWD. 4.0L V6. It currently has 225/70/R14s on it. I'd like to get a bigger rim/tire, just wondering what my options are and any suggestions would be appreciated ! Thanks in advance
Uncle Gump
Token Old Guy
13,438
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You need to consider your gear ratio first.
Should be listed on the door tag if it's the original rear end.
stephen1231
Here is the door tag. could you point me in the right direction?
Uncle Gump
Token Old Guy
13,438
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Code 95 says 8.8 open 3.55 gear.
Any taller of a tire will surely make the powertrain suffer performance wise.
stephen1231
So not recommended to go bigger than 14inch rim? or if I go 15 inch rim get smaller profile for tire??
Uncle Gump
Token Old Guy
13,438
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
you can go 15 inch wheels for sure....
I don't think I would go any taller personally.
ericbphoto
Overlander in development
16,541
Wellford, SC
3.0L
6"
Exactly. You can use a 15” rim but get a tire that has the same outside diameter as your original tires.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Having once owned a 4.0L Ranger with 3.55 gears and 225/70R14 tires, I can safely say there is a little bit of leeway there in going to bigger tires (3.55:1 is a relatively short ratio for 26.4" tires). Going to a 225/70R15 (27.4") shouldn't be an issue (235/75R15 (28.9") should be OK too, though at that point you may infact start to notice some difference as compared to the original (smaller) tires, and the speedo will need recalibrated).
O No 3.0!
62
Knoxville Tn
Ranger xl 3.0
I just put a set of '01 mustang wheels on my 97 with 245/50/16 tires. The tires are a little short, but the difference between those & the 14's is night & day. Completely transformed my truck from a wallowing pig to a fun little truck that handles decently now. I bolted them right on with no spacers or anything & they sit right & don't rub at all. I got them from pull- a-part for about $150 with good tires.
