Mr.Pickle95
- Jun 21, 2020
- 0
- Bedford, IN
- Ford Ranger
Hello all, I'm new to this site. Just got a 4 cyl 5 speed ranger with around 230,000 miles on it, good shape but it has a major driveability issue. It will fire right up, to 1500 rpms and then immediately die. It refuses to idle on it's own and if you tap the gas you can keep it running, but it misfires and back fires until im giving it half throttle. Will run fine if I floor it. As I'm driving it feels like the ignition is cut off until I give it about half throttle and the ignition comes on, there is no engine response until I push the pedal far enough. There were a few instances where this problem suddenly went away and it drove and idled fine, but never lasted long and would revert to running horrible until I really pushed the pedal. I cleaned my MAF sensor as it threw a code showing low input, I also replaced the throttle position sensor, after doing this I made sure to drain the capacitors in the PCM so it would relearn. Still wont idle and I'm not sure what to look for next. Maybe bad ignition coils? Any input is greatly appreciated!
