SirPotato
- Sep 9, 2024
- 0
- Cinci
- b2300
I have a 97 2.3 5 speed that I just picked up in a trade deal. I could use some help on suggestions to get it back running right. This is a long write up but I wanted to be thorough for anyone that is willing to help.
Issue:
Cold start-
1. The truck will not idle
2. Truck will not stay running without applying roughly 1/8th of the throttle
3. Truck sputters and is on verge of backfiring after first starting
4. Driving in this condition, the truck will shut off when slowing down for a stop sign
5. When accelerating, the truck feels great above 2k rpm
After warm up-
1. Truck will idle at 1k rpm and slowly die off to sputtering and finally die out
2. Truck will sometimes "buck" and cut out between 1500rpm and 2k rpm. Applying more throttle will stop it from cutting out, letting off throttle completely will also stop this.
3. If I raise the idle to 1250-1500 rpm using the set screw on the throttle body, the engine sounds fine and does not cut out.
What has been done by previous owner:
MAF, IAC, TPS, Plugs/Wires (one side), Coil Packs, Fuel Pump, Fuel Filter
What I have done:
Fuel Pressure Regulator, checked all relays and fuses, checked all vacuum lines for cracks and leaks
After replacing the fuel pressure regulator yesterday, I raised the idle slightly to 1k rpm and drove the truck for 15 minutes with no bucking/jerking at lower rpm. When I parked the truck, I let it idle and the truck slowly died out over a 45 second span.
Trying to start the truck again, it would rev to 2k rpm's and immediately die unless I maintained a minimum 1/8 throttle while starting and slowly released the throttle. Slowly releasing the throttle would cause the truck to idle but again it would slowly stall itself out. If I adjust the idle screw to 1250-1500 rpm the truck would stay running and not cut out once warmed up.
Thanks in advance to anyone willing to read all this and throw some ideas my way.
*Previously owned 2 other 2.3 rangers (93 and 96), never had an issue like this before*
Issue:
Cold start-
After warm up-
What I have done:
