Crashtest84
- Sep 6, 2007
- 0
- Tulsa, Ok
- ford
- Engine Size
- 4.0
Ok guys so My 2.9 is on its last bit of life, no oil to the heads. So I got a 97 explorer with a 5.0 auto with the awd transfer "already sold". I have some questions now I don't have the explorer in my hands yet. First will the 1354 transfer case bolt to the auto trans that mated the awd in the explorer? Next I looked around and didn't find much on these two models as far as swaps with a 2 inch BL I shouldn't have body clearance issues right?
I'm thinking as far as the motor it should just about bolt right in with stock exhaust manifolds right? I plan on electric fans and using the rad from the explorer. Now Fuel what should I used for a fuel pump aftermarket or factory? I am going to rebuild the 5.0 as it has a spun main "we think" but im going to portmatch the heads and intake and work over the valve pockets. Cam stock or????? I was thinking a B E or F303 but there all made for cars really not something turning 35inch tires thinking maybe custom grind Comp any ideas? Last for now back to the trans my ranger is a 5speed any good idea on a auto shift system, maybe try and swap the whole steering column? I will add pictures and updates as I get things done.
