97 B4000 Question
kjkato
Anchorage Alaska
Mazda B4000
New here but I have a 1997 B4000 with 205,000 miles and the rear end which is an 8.8 373 is totally trashed. Will the rear end from a 2001 Ford Ranger work without any mods or am I better off not venturing down that road?
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm like 99% sure it will bolt right up.
Colin
182
ON Canada
Mazda
Yes, any b series 94+ is just a ranger with a different front clip and bedsides
sgtsandman
Aircraft Fuel Tank Diver
12,533
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I concur, a Ranger axle should bolt right in. Make sure you get new u bolts for the swap. You'll need to check the torque on the u bolt nuts after driving a bit a few times until the nuts no longer rotate using a torque wrench. They usually don't tighten up and stay tight with the initial installation.
kjkato
Anchorage Alaska
Mazda B4000
Ok cool, thanks! Also does anyone know if I can install LED lights in my dash without any mods? Some of my dash lights are out and I figured its time to upgrade.
Colin
182
ON Canada
Mazda
Search "(bulb number) led" on Amazon, rockauto should list the bulb size, it might be 168
sgtsandman
12,533
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
LEDs are usually polarity specific. So do a test before you install the cluster. You might have to rotate a bulb or two in order to get them to work. Don’t panic if they don’t all work on the first try.
Brown_Eminence
conyers, GA
mazda b4000
believe any "8.8" rear end would work out of a ranger, crown vic, mustangs. that should work !
