dwil4
- Jan 31, 2019
- 5
- Brasstown,N.C.
- Ford
So all I get is a click everytime I turn the key but if I go out and stick a screwdriver to the 2 contacts on the solenoid relay or whatever it's called that is mounted on the inside of the driver fender then it will crank.. The truck has been sitting for probably 3 yrs and before that I remember it seemed that it had gotten to where you had to press the clutch pedal really hard in order for it to crank. If I hold the key in the turned position press and depress the clutch it will just click everytime as well. Sometimes the interior bell will continue to "ding" even when you take the key out.
