'95 + Heater core... What a PITA!!!!
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
So I finally got around to changing my heater core today. There's really nothing to hard about changing it out, but it's a real pain in the ass. The write up in the tech Library describes it as a nightmare, I'd say time consuming is more like it, it took me about 4 hrs.
The write up in the library is a huge help, there are a few steps that you don't need to do though, you don't need to pull the steering wheel from the column but the column dose need to come out, the gauge cluster and trim around it can stay, and I suggest pulling the steering column before trying to pry apart the big plug monster in the drivers foot area.
I think the hardest part was the nut holding the heater box to firewall right above the tranny and behind the engine. Over all its not that hard of a job, so if you need to replace yours and not sure if you can do it, its not that bad just be ready to spend some time working on it.
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Did your core actually corrode through? Crack a seam?
Oh well, overall the Ranger's not too bad to work on, esp. compared to just about ANY FWD vehicle.
Wicked_Sludge
42
Westport, WA
3-point-GO
ive rarely had any major trouble working on any FWD vehicles....with the exception of 2.5 contours/cougars. my escorts are friggin gravy....i havnt found a hard R&R on those cars yet.
4 hours is really good for a "noob" you done good southern.
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
I really couldn't see why it was leaking because the leak was between the fins, it was covered in an orange rusty residue tho, when I bought the truck the overflow tank was full of some kind if rusty nastiness and the rad a had plain water it in it so....
Ether way there's fresh coolant in the system and I have working heater now so I'm pretty happy. And I'm with Wicked on the FWD cars, there are some that are a real bitch but for the most part there not that bad. If you wanna see something really rough to work on go take a look under the hood of the new Super duty trucks :fie:
Wicked_Sludge
42
Westport, WA
3-point-GO
those aint so bad after you unbolt the cab and lift it off the frame :D
Wicked_Sludge
42
Westport, WA
3-point-GO
it was a regular thing by the time i left the ford shop to see a 6.4 truck sitting on the ground under its cab on a hoist. you cant do nothing to those things without lifting the cab. the EGR systems are crap. the turbo control systems are crap. and the injectors are crap :sad:
funkingonutz
Enfield CT/LongmeadowMA/AgawamMA
3.slow
yeah i did my heater core right on mothers day....(mom was'nt to happy) i took my time and had it done in 2 days cause i did'nt know u had to pull the WHOLE FRIGGIN DASH!!!!! until i went on here and looked into the tech libary. I think the hardest part was the plug monster.
Yeah i heard about those super duties....pulling the body off the frame does not sound fun at ALL!!
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
Plug monster isn't that bad, a screw driver with a 90* bend it in make quick work of it, that and I pulled the column first so it gave me more room to work with.
Well worth the effort though, I new the heater core was bypassed when I bought the truck last spring and figured no big deal, I'll just wear a sweat shirt. Found out how nice a heater really is.
Pulling the cab from one of those trucks cant be that bad, it just nuts and bolts :D
