95 b2300 no start ?
North Idaho 5.oh
561
Idaho
Ford ranger
For starters this thing has definitely been used. It has 250k+ miles on it but I want to fix it since it’s a 2.3 and also 4x4.
I bought it in the condition that it’s in, non running etc….
So what I know is that it’s not getting any spark, nor is it getting fuel pressure, and also the CEL is not working.
What I have done, … checked the bulb in the gage cluster, and swapped the pcm with another known to be good pcm from a 1997 ranger with the same configuration. Also I have checked fuses, relays, etc…. Still the same thing, no start. Will crank all day and it sounds like it’s got good compression (haven’t tested) and the timing belt is intact and not loose at all…. I’ve never dealt with these engines before so any suggestions are much appreciated!
Colin
187
ON Canada
Mazda
Figure out why it doesn't have spark, then check if the pump is running, then if the injectors are firing
rusty ol ranger
2.9 Mafia-Don
8,056
Michigan
177 CID
North Idaho 5.oh
561
Idaho
Ford ranger
Pump is not running, I did confirm that. I will be installing a crank sensor, but I have my doubts. With the CEL not working, that’s where my concern lies… or am I missing something? Lol
Colin
187
ON Canada
Mazda
Figure out why the pump isn't running first. The fuel pump doesn't care about a crank sensor signal.
North Idaho 5.oh
561
Idaho
Ford ranger
Sounds good. I’ll go over the same things I did yesterday… maybe I missed something. ?
Colin
187
ON Canada
Mazda
Ignition on, check for power and ground at the pump. Might only have 12v for a few seconds while it tries to prime the pump, should be constant while cranking. If that's good then try powering the pump directly
scotts90ranger
4,885
Dayton Oregon
2.3 Turbo
If you don't have spark or fuel pump it sounds like the ignition isn't turning on, I would check the key on power in some places, I think there's a keyed power on the OBD II port or disconnect the ECM and check on the pin there, either that or there's a bad ground somewhere... any bad fuses in the power distribution box?
TexasDuck66
July Truck of The Month
