95 B2300, coil issue with 2.3l engine
dfratus
MCNEAL, AZ
2003
mazda
RANGER
Hey ya'all. This is my first post. I'm having problems with low power and I'm getting a code 352 saying there's a primary circuit malfunction on coil B. Which one is B? and how can I check it out? Should I just replace it or could the problem be something other than the coil? The truck has 31" tires and fancy aluminum wheels that I'd like to get rid of and use some more practical ones. I'll bet the large tires could be affecting the performance and they rub the wheel wells in the front when I hit a rough spot in the road. I don't do any off roading on purpose but I do live on a dirt road that gets pretty muddy at times. Thanks for any advice you can offer.
Insanejughead
29
Missouri
'94, '86
2.3T
Your second coil may be bad. Do a search on how to check your coil packs, and then check what you find with what is factory specs.
While you're at it, check the resistance on all of your spark plug wires.
Hell, give the spark plugs a check, too.
dfratus
MCNEAL, AZ
2003
mazda
RANGER
Insanejughead,
Thanks for the reply. I'll try your suggestions out.
