Wanted 95-97 d35 ttb ranger knuckles
bort
ca
Looking for 95-97 ranger ttb steering knuckles and spindles if they're in decent shape. Specifically the knuckles for the bolted two piston caliper.
SenorNoob
520
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
NakedDucks
63
B’ham AL
I can get you a set. Do you already have the matching beams? The knuckles alone won’t do you any good unless you have the 95-97 beams too. The ball joints and steering stops were different.
SenorNoob
520
Middle Tennessee
245-70-R16
Why won't the knuckles themselves work? I get that you have no steering stop that way, but; mines been like that for years now. I just don't make a habit of turning the wheel all the way to lock.
NakedDucks
63
B’ham AL
The ball joints were different sizes on the 95-97 beams.
SenorNoob
520
Middle Tennessee
245-70-R16
Gotta look and see how I made it work then... Don't remember having a problem.
SenorNoob
520
Middle Tennessee
245-70-R16
I used Masterpro K8673 and K8676 for a 96 Ranger.
I see they're only listed for 93-97. I know my axle was from a 92 Explorer. Maybe late 92?
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
Were are you located? I have a set of knuckles, calipers, spindles, probably even some spare stub shafts and Warn lock outs in central Ohio.
NakedDucks
63
B’ham AL
PlumCrazy,
If he’s not interested, I would be interested in the Lockouts.
North Idaho 5.oh
540
Idaho
Ford ranger
The knuckles with the dual piston caliper (95-97) will work on anything from 1991-1997.
I had that exact same set up on my 92 ford ranger with a 6 inch lift and 33’s and it worked just like the 92 knuckles would.
I suggest doing a little more research on the matter before making your decision.
IMO it’s a great upgrade and I had no problems with it.
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
Kirby N.
March Truck of The Month
