2.3L ('83-'97) 95-01 2.3/2.5 Head on 94 2.3 Block
Trippy
Alabama
235 75 R15
I'm sorry if this has been covered before. I have been looking for a few hours now and cant find a straight answer.
Can I safely use the the cylinder head from a 1997 -2001 2.3/2.5 Lima engine on a 1994 2.3 Lima block. The head gasket part number seems to be the same but the coolant passages seem bigger on the 1997-2001 head.
I realize that the alternator and ignition coil bracket might have to be swapped to the later style one.
Also, as I understand it, the camshaft gear might have to be swapped for timing marks to line up.
Thank you in advance for any information you can provide.
scotts90ranger
4,227
Dayton Oregon
2.3 Turbo
I believe you should be fine, the square tooth timing belt change was in '92 I believe so I don't think the cam/aux pulley should be any different. The coolant ports in the head gasket are usually the restriction and on purpose so I think you are correct in your assumptions.
Kirby N.
March Truck of The Month
