I would confirm #1 compression stroke and rotor position.
Firing Order 1-4-2-5-3-6 Clockwise rotation
To have ALL cylinders not firing wouldn't be a head issue, compression is also a long shot since it would have to effect ALL cylinders to prevent any firing.
Usually it comes down to spark or fuel with a no start on an engine with a timing chain, timing belts can break, so no start, timing chains can skip so less power but rarely a no start.
If you added fuel manually and still no firing then it is down to spark, that is where I would focus the time.
TFI testing is outlined here:
http://www.therangerstation.com/tech_library/TFI_Diagnostic.shtml
There is a separate START and RUN power path for TFI, that is why I mentioned using the jumper wire from the battery to the coil.
When you turn the key to START the power for TFI and coil go thru a Safety switch, Clutch switch or Park/Neutral switch, and RUN power is cut off, if the safety switch is not passing the START power then spark won't work while cranking engine, but you will have power at TFI and coil with key on(RUN), so it can be perplexing, you have power but no start.
