Bubbax
- Oct 3, 2022
- 4
- Northwest
- Ford Ranger
Hello
I have a 94 Ford Ranger
Extra cab with a 4.0 litre engine,
M5OD-R1 5 speed transmission
Rear axle ratio 3.08
175,000 miles
1st and 2nd syncros seem to be worn out > Shifts fine on cools days for a few miles then 1st and 2nd grind unless I am real careful shifting.
I can shift into 1st without grinding if I apply the clutch for about 10 seconds
No problem shifting into reverse 3 and 4 grind every so often fairly rare.
I an considering replacing the transmission with an M5OD-HD from an newer Ranger.
My concern is the difference in 1st, 2nd and 3rd gear ratios.
Gear M5OD-R1 M5OD-R1HD
1st 3.72 3.40
2nd 2.20 2.05
3rd 1.50 1.31
4th 1.00 1.00
5th(OD) 0.79 0.79
Reverse 3.40 3.40
4.0 litre
3.08 rear rend
The OHV engine is supposed to have 40 more hp
I occasionally pull a 15 foot boat with no problem
Will I notice much of a difference with the lower gear ratios?
Also will there be a problem connecting the speedometer ?
Is it difficult to rebuild the M5OD-R1 transmission?
I am mechanically inclined and I can follow directions. Fair amount of engine experience.
Thanks in advance
Bob
175,000 miles
1st 3.72 3.40
2nd 2.20 2.05
3rd 1.50 1.31
4th 1.00 1.00
5th(OD) 0.79 0.79
Reverse 3.40 3.40
4.0 litre
3.08 rear rend
Thanks in advance
Bob
