LeIvoryCrow
- Jun 8, 2019
- Reaction score
- 0
- Location
- 56345
- Make / Model
- Ranger
- Manual
Bought a $500 94 2.3 manual Ranger now having some starting issues, hopefully you guys can help sort it out
-Ran ok, had a miss when I bought it.
-Adjusted timing now only runs while cranking
- while cranking I can rev the engine and it runs fine, no misses
- replaced, plugs, IAC, fuel pump, fuel filter, ignition switch, injectors, thermostat and housing (leaking).
Previous owner replaced coils, radiator, timing belt, and Icm <used>
I have power to coils key on and off,
power to injectors key on.
Cleaned all the grounds.
Maf tested good.
Relays tested good,
40 pounds fuel pressure.
Obd scanner is not reading codes <I think the connector is bad>
Will run off ether for a few seconds after switching key to run.
At one time it was running after messing with the wires under the dash. I shut it off tried restarting same issue.
Vacuum hoses could be replaced, besides that I am lost on where to check next.
Thank you for your help
Maf tested good.
Relays tested good,
