Bruce
- Feb 29, 2008
- 1
- Southwest Missouri
- Ford
- Engine Size
- 4.0 SOHC
A couple weeks ago the front brakes locked up and of coarse it smoked the pads. It had the original calipers so i replaced the calipers with rebuilt which had the steel pistons and of coarse replaced the pads, rotors where ok. I put my snapon scanner on it and pulled codes for the ABS and had a code 67 ABS pump. I guess my question would be...could my ABS pump cause the front brakes to lock up. Since replacing calipers have not had a problem with brakes only the ABS light comes on and off and code 67.
Thanks in advance..Bruce
