- Mar 6, 2020
- 1,110
- 48022
- Ranger Splash
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
Been scrounging around trying to find the right place to post this. It's a common problem that I've seen in a bunch of different places. It's the dreaded "CLICK" when you turn the key to start. I know RonD has thrown down a lot of help on this as well as many others. I just got the girl back on the road a week or so ago and everything has been great. Took her to the store and back. Parked in the barn when I got back. Went to start it a few hours later and got the click. Battery voltage is 12.53 at the posts. Same at the relay. I did not measure at the starter motor, but pulled it and bench tested it (well more like fender tested it). Everything works as it should - motor and gear spins up and the solenoid kisks the gear out.
So now I'm at the relay. I have the 4-poster and am playing with the multimeter looking for continuity. I say playing cuz I do not understand. When I measure from the "S" post to ground, I get an audible beep and the numbers in the pic - 3.2 Is that good or bad AND what else can I measure to help determine if the relay is bad?
It starts at 3.5 then settles down to 3.2.
As always, thanks. I know you prolly get tired of answering the same questions, so if you can point me somewhere - No Dirtman, not there - I'll be happy to go.
