94 4.0 V6 poor idle/ dies when in gear
Shokie1555
New member
Holly
It has new gas and yup correct the firing order is correct
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
JMF661
Active member
45
Bakersfield, California
Ford Ranger XLT
Stock
31” x 10.5”
Did this start immediately after you pulled off the upper intake manifold and reinstalled for the injector job?
Maybe a wasted vacuum line? Bad injector connection?
Shokie1555
New member
Holly
No it ran pretty good after replacing injectors but it didn’t have enough power so I looked at the other bank and found a cracked injector so I replaced the other bank then put it back together then when I tried to start it, it wouldn’t and that’s how I found out that the relay was bad
gaz
Active member
30
Wa, Bremerton 98310
2.9l
Shokie:
Were all 6 injectors replaced, exact same brand, model and flow rate?
If I pulled and replaced an injector bank, then had problems, the 1st thing I would do, is check that bank of injectors. I would pull them, inspect the harness, connections/pins, donuts, caps and how well the injectors were seated; then carefully reinstall them.
