If it starts and runs by manually adding gas to intake and then dies when you stop adding the gas........
I would say Fuel pump is not working.
In Rangers the fuel pump in the tank should come on for 2 seconds when key is turned on, it is not that quiet so you should hear it.
Try turning key on, count to 3, then turn key off, repeat, listen for Fuel pump.
If you hear it, check for fuel in the tank, I know, gauge says there is gas, but IS THERE GAS in the tank.
If pump comes on and there is fuel in the tank then try replacing Fuel Filter($10), it is in the frame rail approx. under Drivers seat.
And with filter removed put a bowl or bucket under fuel line and cycle key on, make sure fuel squirts out of the line.
A dirty fuel filter should not keep engine from starting, symptom is losing power at highway speeds, but starts and idles fine, so a long shot, in a no start.
If you don't hear the pump then check for power first.
In the engine fuse box is a 30amp fuse for the FP(fuel pump), check it.
There is also a Fuel Pump Relay in this box, have some one turn on the key while your finger is on the FP relay, you should feel and hear it click.
The EEC relay is right next to the FP Relay, it will also click with Key On.
If FP relay is not clicking then swap it with WOT relay if there is one, see if that one clicks, WOT relay is used for A/C so may not be there, so you may need to get another relay($8-$10)
In the passenger side inside the cab, is the Inertia switch, under the glove box and maybe just under the top of the carpet(could be behind kick panel as well), it will have a Button on the top, this is a reset button.
Inertia switch will cut power to fuel pump if it is banged hard, i.e. an accident or rollover, this prevents fuel from continuing to feed any fire
There are two wires attached, 12v in(from FP Relay) and 12v out (to pump)
You can use a test light/volt meter to see if there is 12v on both when key is turned ON, remember voltage is only there for 2 seconds.
You can start here if you want, if you have 12volts on both in and out wires then fuse and relay are working.
If all checks out OK then you will need to replace the pump in the tank.
Some drop the tank, others remove the bed to swap pumps
